I have a launchpad that I did setup for use in conjunction with my DDJ-400's, but I want to use VDJ to export audio clips and use the launchpad in fl studio. I can't figure out how to remove ddj-400 from vdj sw.
I looked at this, but I don't have an "ignore" option or a controller windowhttps://virtualdj.com/forums/221044/General_Discussion/Disable_Controllers___Midi_-_Leaving_access_for_other_apps__.html
I do have a "mapping" option that shows the ddj-400, but no ignore
geposted Sat 16 Jul 22 @ 4:01 am
NM, found it
Mapping - on right side, you can deselect a mapping and choose ignore
geposted Sat 16 Jul 22 @ 4:04 am
