Topic: deck cloning
I know that in the old software mapping that we can clone the deck. will this feature be updated to the current version of virtual dj
geposted Mon 18 Jul 22 @ 2:15 pm
It's already there
You can either use the buttons in the skin, which just requires that you to clean/eject the deck first. Then it's the bottom icon to the left of the platters
Or you can use the double-click option on load buttons on most default controller mappings (often labeled as "instant doubles")
Or you can map it to a button yourself: Then you use clone_deck or clone_from_deck depending on if you want to do it on the deck you want to clone from or the deck you want to clone to
geposted Mon 18 Jul 22 @ 3:06 pm
