right now for scratch bank its to hard to drop in your own samples and its not as easy as sdj
page of 8 seems very limiting . i want there to be a drag and drop on each scratch bank pad
with the sampler it would be nice if there was a record to sampler over each pad by right clicking over it or via hitting shift and the sampler button you what with your midi controller so that i can send my loops over to the sampler . the sampler would also record what ever you do with your fx and eq in that loop when sending it over
geposted Thu 28 Jul 22 @ 1:42 am
For the scratch bank, use the 'edit' button of the scratch bank pads to open the scratch bank editor to add as many banks as you like, and drag&drop songs on the pads there.
For the sampler, "sampler_rec 1" script will record directly to slot 1 of the recordings bank, so you can use it immedately.
geposted Thu 28 Jul 22 @ 2:55 am
