Hi,
I am not using a controller, strictly keyboard. No external soundcard. I just wanted to use automix to make a recording of a bunch of songs to play anywhere I can play an MP3.
For some reason, all I can record is my mic input of me talking, even though mic is turned off under Master settings. I don't want me talking in the recording at all. Just the music.
Here are my setting choices. Any help would be appreciated.
geposted Sun 31 Jul 22 @ 3:29 am
try removing the record line from audio config
geposted Sun 31 Jul 22 @ 4:23 am
Like posted you are not trying to record from an external source, but instead directly from inside the software. So there should be no record input entry in the audio config
geposted Sun 31 Jul 22 @ 11:10 am
