Topic: effect_disable_all command
the above command stops all effects in progress which includes the color fx..which means if u are using the color fx and activate the command..yes the color fx stops but it also disables the switch to turn on a color fx..so u have to manually reclick it to use it as if u turn the filter knob..the parameters are adjusted but the color fx itself is off...the above command should just reset the filter to 50% as this is effectively stopping the color fx...yes you can map the filter knob to filter on & colorfx or use the filter_activate command as a workaround but it shouldn't have to be so complicated....
geposted Tue 23 Aug 22 @ 4:18 am
