still having problems recording songs after i downloaded and intstall virtual dj 1.07b. when i click on the record button nothing happens.
record into single file-does not work even with auto start
record into multiple files-does not work even with auto start
record into a ready to burn cd file-work
broad cast onto the internet-don't know dont use this feature
would appreciate you guys fixing this. this is one of the main reason why i like this program.
geposted Wed 12 Nov 03 @ 9:07 pm
i dont have this problem at all.everything works fine!!!!must be something else!!!!
geposted Wed 12 Nov 03 @ 11:43 pm
wounder what it could be then. i tried re installing but it did not work. anyone have any other suggestions?
geposted Thu 13 Nov 03 @ 2:24 am
Do a complete unistall of your current version and download and install virtualdj 1.07b again.
Remember to reboot your pc after you install virtualdj (sometimes it helps)
geposted Thu 13 Nov 03 @ 3:09 pm
I did a complete uninstall and installed again and im still having problems with recording...also im not sure if the install app i have is the beta version since it says "install_virtualdj_v1[1].07" but when i go to my update page it says "You have already downloaded the latest patch install_virtualdj_v1.07b.exe" .....either way i cant record
geposted Thu 13 Nov 03 @ 9:56 pm
So you must have the good install somewhere in your hard drive, try a search with "virtualdj" cause you are trying to reinstall the first version, and not the beta.
FRUiT94
FRUiT94
geposted Thu 13 Nov 03 @ 10:21 pm
Thanks for the advice....i did a search though and the only install app that comes up is the one on my desktop "install_virtualdj_v1[1].07"...is there anyway someone on the team could reset my profile so i could dl the beta version and see if the recording works then? thanks
geposted Thu 13 Nov 03 @ 10:26 pm
mpower44, go here : https://virtualdj.com/support/e-service/
geposted Thu 13 Nov 03 @ 10:39 pm
Download VirtualDJ again.
geposted Thu 13 Nov 03 @ 10:52 pm
well i uninstalled and re downloaded the program, installed it and now it still will not record and when you mix songs together it skipps and freezes. i think i am worse off now. could i get some help or something. i realy like this program. i have spend 6 hours in deleting, downloading and reinstalling this program to no end. now even the origional program does not work. please help
geposted Thu 13 Nov 03 @ 10:58 pm
after the full re-install... did you re-boot?
geposted Thu 13 Nov 03 @ 11:09 pm
When you re-install, have you closed all program in background ? (antivirus, firewall…)
Try this:
1- Uninstall and re-boot
2- Close all program in background
3- Re-install and re-boot
Good luck
Try this:
Good luck
geposted Thu 13 Nov 03 @ 11:17 pm
In VDJ, go to the setting pannel, then click the "infos" tab, here must be "version 1.07b" written.
geposted Thu 13 Nov 03 @ 11:25 pm
cyote, tried your way and it didn't work. i even ran a search and deleted all virtual dj before i rebooted and it still did not work. what is up with this program? i am realy sad now. paid for it and it does not work.:(
geposted Fri 14 Nov 03 @ 5:17 pm
Here is another way.
1- Uninstall
2- Run regedit and delete the key HKEY_LOCAL_MACHINE\\SOFTWARE\\VIRTUALDJ
3- Delete the virtualdj folder
4- re-boot
5- Close all program in background
6- Re-install and re-boot
The install MUST be install_virtualdj_1.07b.exe.
FRUiT94
1- Uninstall
4- re-boot
FRUiT94
geposted Fri 14 Nov 03 @ 5:28 pm
Nitr0: You haven`t downloaded the last version again yet.
Delete any other install file you have. Download the last version again and then follow every step we wrote here.
Bye
Bye
geposted Fri 14 Nov 03 @ 7:22 pm
Fruit,
worked like a charm buddy!! many thanks to you. now i can go back to mix'in music. again thank you very much.
geposted Tue 18 Nov 03 @ 4:43 am
Good mix Nitro Keep up the good work!
geposted Tue 18 Nov 03 @ 8:46 am
can you tell me how to record with or from virtual dj
geposted Fri 26 Mar 04 @ 9:00 pm
