Topic: Denon Prime 4 modified screen
Hi Guys, I have a Prime 4 and I downloaded the modified screen for it. they say to make it work you need to rename the zip file (done it) and after that you open VDJ, computer mode in the Prime 4, and the modified screen should show in your Prime 4 so when you load a video file the video icon would show and you can see the video in your Prime 4 screen. but in my case it only shows in my laptop screen not in the Prime 4 screen. am I am doing something wrong? no matter what I do I can't get the Prime 4 to get the video on the Prime 4 screen. please help
geposted Fri 02 Sep 22 @ 9:05 am
djmilaPRO InfinityMember since 2008
geposted Fri 02 Sep 22 @ 9:37 am
Can you post picture of your Skin folder and picture of interface settings in VDJ?
geposted Fri 02 Sep 22 @ 9:38 am
VDJ will automatically load to the Prime 4 screen the skin named as .. Denon Prime4 Screen.zip , so make sure the zip file is named as such in /Documents/VirtualDJ/Skins folder.
You should not select this skin as your primary screen skin (from Interface tab of VDJ Settings).
geposted Fri 02 Sep 22 @ 12:36 pm
