Topic: Search
Hello all i have a scan running for all most 4 days on my 6tb ex hard drive then we had a power cut
So now if i do a search for songs it cant seem to find the songs .is they a way to fix this if possable ?
geposted Fri 02 Sep 22 @ 8:37 pm
Re-add them to database,by multi-.selecting everything. right click and select Batch -> Add to search db
Even if you then have lost some om the analyze data for the tracks, the search for track name, artist and other tags will work
geposted Fri 02 Sep 22 @ 9:11 pm
Ho ok the same way as i was doing them be four
Cheers for the help
Thank you
geposted Fri 02 Sep 22 @ 9:43 pm
