I'm using b7059 with pioneer ddj1000 srt.
pro infinity licence
latest drivers and firmware installed.
usually after 30 or 60 mins the music stops, high pitched noise for 5 secs and vdj has frozen. It happens the instant I hit a hot cue every time.
tried setting stems to only use precomputed, turned off wifi and bluetooth, still happens.
I got this info from error logs but don't know how to interpret it
Can someone work out what this means please?
Source
VirtualDJ
Summary
Stopped working
Date
2/09/2022 7:52 PM
Status
Report sent
Description
Faulting Application Path: C:\Program Files\VirtualDJ\virtualdj oct.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: virtualdj oct.exe
Application Version: 8.5.7059.0
Application Timestamp: 62e2af13
Fault Module Name: StackHash_0860
Fault Module Version: 10.0.22000.832
Fault Module Timestamp: 3907dfbc
Exception Code: c0000374
Exception Offset: PCH_BA_FROM_ntdll+0x00000000000A4B84
OS Version: 10.0.22000.2.0.0.768.101
Locale ID: 3081
Additional Information 1: 0860
Additional Information 2: 086013fd4f71d8918cb1b64e73b5212e
Additional Information 3: a804
Additional Information 4: a804f5af346910a1396c356ff704ab98
Extra information about the problem
Bucket ID: 88c1c59d7acd2a4afa4b2cc73fbbd095 (1894657302518812821)
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Hang" />
<EventID Qualifiers="0">1002</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>101</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-08-26T21:11:51.8395810Z" />
<EventRecordID>15220</EventRecordID>
<Correlation />
<Execution ProcessID="2908" ThreadID="0" />
<Channel>Application</Channel>
<Computer>LAPTOP-MCFJQ1S7</Computer>
<Security />
</System>
- <EventData>
<Data>virtualdj oct.exe</Data>
<Data>8.5.7059.0</Data>
<Data>4310</Data>
<Data>01d8b98a5b6cd08c</Data>
<Data>3</Data>
<Data>C:\Program Files\VirtualDJ\virtualdj oct.exe</Data>
<Data>2af6ca35-db72-4baa-a55f-2b4b78597328</Data>
<Data />
<Data />
<Data>Cross-thread</Data>
<Binary>430072006F00730073002D00740068007200650061006400000044006500610064006C006F0063006B0000000000</Binary>
</EventData>
</Event>
Source
VirtualDJ
Summary
Stopped working
Date
2/09/2022 7:52 PM
Status
Report sent
Description
Problem signature
Locale ID: 3081
- <System>
<Level>2</Level>
<Task>101</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
- <EventData>
<Data>4310</Data>
<Data>3</Data>
<Data />
<Data />
</EventData>
</Event>
geposted Fri 02 Sep 22 @ 8:47 pm
Hola a mi también se me presenta el mismo problema pero en mi caso es con una Denon Prime 4, en ocasiones se me detiene la reproduccion y luego sigue sonando. Esto es un error bastante molesto ya que yo mezclo totalmente en vivo, escribi un caso a soporte de VDJ pero no me pudieron ayudar en nada, solo me pidieron informacion y luego de eso me dejaron de responder
geposted Sat 22 Oct 22 @ 3:44 am
UPDATE
I have stopped using cue loops and changed settings to load song at first cue point,
From there I can set loops manually if I want them.
Several weeks now and no crashes, this seems like it has fixed the problem (fingers crossed)
geposted Wed 23 Nov 22 @ 1:31 am
Аналогичная ситуация была у знакомого с numark ns6 ii. Именно на hot cue 1. Просто стали использовать hot cue 2.
A similar situation was with a friend with numark ns6 ii. Precisely on steel hot cue 1. Just use hot cue 2.
geposted Wed 23 Nov 22 @ 9:20 am
