In my Skin the Scratchwave isn't full size (1920)
I have on both sides a Button. My Waves starts at +16.
When i use "save loops", the on Wave Marker starts 16 Pixel before the real Position.
The Loop starts on the correct Position and the Loop Markerm when the Loop is on is also correct.
Look at the Screenshots.
I think, there miss a pos x="" for the Marker.
Wave starts at +16 (the Marker is on the wrong Position)
___________________________________________________________________________________________________
Wave starts at +0 (the Marker is correct)
when the loop is on (the Marker is correct)
geposted Sat 03 Sep 22 @ 11:04 pm
additional infos:
Here you can see it much more. The marker comes from the new Auto-Trigger.
Build 8.5-64 b7122
Build 8.5-64 b7122
geposted Sun 04 Sep 22 @ 12:14 pm
I didn't understand anything
geposted Sun 04 Sep 22 @ 12:55 pm
Will be fixed in next update
geposted Sun 04 Sep 22 @ 1:07 pm
