I want to make a button that when I press it select the loop in point and when I stop holding it select the loop out point (also if there's a way to detect which deck is in pfl to then select the loop only for that deck it would be very helpful)
PS: I'm going to keep using virtual DJ but if this is just impossible in VDJ I'm wondering if in other softwares like serato it may work (will stay in VDJ due to incompatibly problem with my table but I'm wondering for the future)
geposted Sun 04 Sep 22 @ 2:38 am
It sounds like you are describing standard loop roll
If so that is already on the pad pages, which is always deck dependent
If you need a pre-mapped way of handling pad pages from your keyboard, you can use the Pads to Keyboard mapping from under extensions
geposted Sun 04 Sep 22 @ 12:02 pm
down ? loop_in : loop_out
geposted Mon 05 Sep 22 @ 12:25 pm
