hi guys im hoping you can help with possibly a very simple problem i have. im an oldschool dj and am used to running everything through mixers but an now doing a show on an internet radio station and im encountering a few issues. at the min i have a denon mc3000 controler (older but still solid) and have the issue that it has no mic eq. buying a new controller isnt an option as im disabled so cash is really tight.
the denon is set as my main pc soundcard and im running the rec out to the line in on my pc so that se caster can see it and broadcast the stream. this way i can use my speakers to hear my mix in my room without the latency delay.
i have a verrrrry old gemini ps 262pro mixer set up so i can eq my mic (shure mv7x) and then feed master output from that to mic input on the denon. this lets me clean up my bass a little as i have a bass heavy voice and the zero graphic option on the denon sounds awful
what i want to do is find a way to feed my mic into the pc alongside the denon while still being able to hear it in realtime. using the "listen to this device" setting in sound settings has an unusable latency.
i want to be able to add a compressor and a noise gate as well as eq the mic in software to sound more like a broadcaster on my show.
before i would have set up an eq rack, a gate rack and a comperssor rack unit then plugged that into the denon but both space and cash prohibit that.
sound empire caster has only 1 input so i cant just use 2 seperate programs as i cant find a way to combine the 2 sources into 1 output. its frustrating and possibly not explained well but im hoping someone here can make sense of my gobbldeygook and talk me through a simple way to sort this.
oh and not using an external audio interface for mic, i have an xlr to usb cable for that and zero cash to add anything else
any help would be great
geposted Sun 11 Sep 22 @ 12:59 pm
i gave you an answer over here https://virtualdj.com/forums/248232/Music_discussion/vdj_and_streaming_with_usb_mic_interface.html
bad idea to double post
geposted Sun 11 Sep 22 @ 1:32 pm
