Topic: Rename File Functionality has changed recently
Since the last update v8.5 - b7131, I've noticed that the behaviour of the rename file functionality has changed. When CleanTagsInDeckDisplay is set to Yes, VDJ no longer gives the "rename to" options based on the actual tags values of the file, but instead the options are based on those "cleaned" values being displayed or are likely to be displayed on the deck.
Is this the case with anybody else?
geposted Tue 13 Sep 22 @ 11:18 am
Yes. I'm not sure what the reason was for this change, when a possibly better suggestion would be to have the option of Rename As Clean Tags being added to the existing two rename options.
geposted Sun 18 Sep 22 @ 6:09 pm
