Topic: Exporting folders to CDJ
Hello everybody,
has ever since the update the possibility been offered to export whole folders to the CDJs? I haven't been able to find this option and would like to know if its possible before I use all of my free time to export the songs each. (:
kind regards
geposted Tue 13 Sep 22 @ 12:22 pm
Because of CDJ database structure logic, you cannot export "entire folders"
CDJs (Rekordbox) logic is based around playlists.
However it's 3 clicks easy to create a playlist out of a given folder and export that playlist.
So, the correct answer is:
Technically no, but practically it's super easy to do so.
PS: There's one catch:
You cannot have "subfolders"
Therefore if you have a folder with subfolders you need to export each subfolder as its own playlist.
geposted Wed 14 Sep 22 @ 7:46 am
