Topic: XDJ-RX3 and VDJ effect slot defaults
Can i do anything for this proplem?
When power on RX3 VDJ three effect slots always changes somekind default settings -> distortion, echo and wahwah. I must change these back my own settings, they save ok and still there if RX3 not connected. And same happend pads slot, there always change Hot cues if RX3 is connected.
geposted Wed 14 Sep 22 @ 9:01 am
You should be able to script this in the ONINIT on the keyboard mapping
Since initializing the keyboard is probably faster then the controller, you may want to start the script with a couple of seconds wait, so that the rest of the script happens after the controller has been initialized
geposted Wed 14 Sep 22 @ 9:11 am
Ok, i'll try that. Anyway, that not happend ddj-1000 and other..is that somekind rx3 feature ?
geposted Wed 14 Sep 22 @ 9:47 am
