I have been having this issue for awhile now probably for the past three years now . I have had this problem on both my rane one controllers and Pioneer ddj800 . This is happening on three of my asus laptops . I have even gone to as reformatting all three laptops and same issue . So what is happening is at some point into my set I get this really bad distorted robotic sound coming out of my speakers , If i close down Virtual Dj and reopen the problem is gone for the time being . I have talked to so many people I am at my end on this as this should not be happening . I have done everything to try and resolve this problem I do not know what else to to .
geposted Thu 15 Sep 22 @ 7:05 pm
have you tried latencymon
https://www.resplendence.com/main
geposted Thu 15 Sep 22 @ 8:49 pm
You didn't mention the size of your ASIO audio buffer...
If it's set lower than your equipment can handle, it could be the cause.
geposted Fri 16 Sep 22 @ 5:13 pm
Your Fix is HERE...
LINK: https://www.virtualdj.com/forums/239972/VirtualDJ_Technical_Support/Rane__One_Problems.html
geposted Sat 17 Sep 22 @ 1:59 am
