what is the signal from the Jogwheels? HID? is it fully supported in VDJ? or through some kind of transformation
geposted Wed 21 Sep 22 @ 12:14 pm
Yes, the S2 mk3 is natively supported in VDJ
https://virtualdj.com/manuals/hardware/ni/s2mk3.html
Remember that you need a VDJ license for it to work for more than a 10 min test period
geposted Wed 21 Sep 22 @ 12:25 pm
klausmogensen
it doesn't say anything about HID, and you're not a developer
geposted Wed 21 Sep 22 @ 12:32 pm
If it wasn't fully supported, then it wouldn't be on the list
That's how it always is with VDJ natively supported hardware :)
geposted Wed 21 Sep 22 @ 12:45 pm
REV7 does not support some function, but it is in the list
geposted Wed 21 Sep 22 @ 12:49 pm
Please give me an example, because as far as I know all buttons/functions on the rev 7 are mapped and have a function when used with VDJ
If you like you can read it here - I don't see any place where it says "no function in VDJ" or "unmapped in VDJ" or something like that, but I could be wrong of course
https://virtualdj.com/manuals/hardware/pioneer/ddjrev7/layout.html
geposted Wed 21 Sep 22 @ 12:53 pm
https://youtu.be/nqMJqtW9bjI
on 17s listen "smooth echo".
geposted Wed 21 Sep 22 @ 1:11 pm
Smooth echo is indeed included when using the rev 7 with VDJ (see point 4 below from the VDJ hardware manual for the unit)
It's actually a hardware effect on the rev7, in which case it doesn't really matter what VDJ can do - it will simply work because of the hardware
But it's also a software effect directly in VDJ, that you can use even without the rev7
However that's not what I meant
Full native support in VDJ does not mean that it will be mapped to do exactly the same as what other software does.
Instead it'll be the feature the devs think is the best VDJ can do which also makes sense in relations when the button/fader
VDJ can for instance do stems separation. So can djay pro - but no other DJ software can do that at the moment, so for hardware where stems separation is mapped in VDJ, that mapping will of course not be the same in Serato or Rekordbox, since those software don't have the feature
geposted Wed 21 Sep 22 @ 1:49 pm
