Hello, I'm to setup my keyboard mapping so I can press the left or right arrow keys and have the program cross fade for me and load the next track. The Mapping command mix_and_load_next works great, but sometimes it allows to auto sync or auto pitch match to come on even when its turned off. It is very inconsistent too. Sometimes it syncs and changes my pitch and sometimes it doesnt even when its turned off. It wouldn't be so bad if the auto pitch_reset worked, even though I have that turned on I can never seem to get that feature to work ever. Any thoughts as to what's going on?
The mix_and_load_next command works fine when automix is turned on but not when its turned off this is when it periodically auto changes my pitch and BPMs and wont auto reset it. Anybody out there know enough to help me write a script to resolve program? I'm thinking something like mix_pitch_reset_and_load_next. Would this work if automix was turned off or on, with or without auto sync and auto BPM turned on?
Thanks in advance
Thanks in advance
geposted Thu 06 Oct 22 @ 7:28 pm
