When I use virtual with no controller, wave forms are big. Using sx3 it shrinks them way down and small. They are high quality files
geposted Sat 08 Oct 22 @ 1:21 am
The Waveform where shrink by he "GAIN/TRIM" Knobb
geposted Sat 08 Oct 22 @ 7:40 am
Make sure you use autoGain, and dont touch the gains unless it's a rare occation where yhe autogain is not correct
If you then find the system is generally "running hot" (it happens with some hardware/controllers) lower the zeroDB setting
geposted Sat 08 Oct 22 @ 2:20 pm
