Topic: Weird LED Meter issue - Prime 4
I'm not sure if this is related to the latest VDJ updates of the latest Prime 4 updates or both...But I only noticed this happening this week.
I always set my gain manually using the trim knob. What I noticed is that, if I turn it too high, the blue LED lights as it normally would, but then STAYS lit until I stop the song. This was with the latest beta of VDJ I think. I then rolled back to the latest stable version, and it did something similar and stayed lit for a while, then gradually lit each led underneath till it went back to normal.
Not sure if its fomenting simple that I've done/changed?
Thanks!
geposted Mon 10 Oct 22 @ 1:08 pm
Looks like it is related to fw 2.3.2 of Prime 4. Happening to me as well.
Not related to firmware (Engine OS). It appears that the VU Meter Peak led is not getting updated fast enough (can take seconds). We are looking into this and will provide a fix soon.
Until then, you could delete the action assigned to the VUMETER_PEAK key or go back to Build 7131
Thanks DJ DAD
Actually a fix is available in Early Access 7166
That was fast. Thank you
Many thanks, will try it out this weekend
