I am in the process of upgrading my old back up laptop to a newer one. (PRO VERSION) I have loaded the software and my library and it worked to perfection (big fan of VDJ!!), but I noticed the new laptop's library is virgin with no cue points or anything which makes sense because I loaded it from my back up hard drive. Is there a way to load the library version from my daily user laptop so it retains all of the current tags like # plays & bmp fixes and also the cue points, etc?
geposted Mon 10 Oct 22 @ 1:16 pm
If it matters, I use the DDJ-400 and windows 10, would love a link if there is a way to do it. Thanks in advance for any tips and tricks!!
geposted Mon 10 Oct 22 @ 1:17 pm
Have you follow the backup manual?
Have you search?
https://virtualdj.com/wiki/How%20to%20Transfer%20To%20A%20New%20Computer.html
Have you search?
geposted Mon 10 Oct 22 @ 3:59 pm
