Aloha,
Signed up to broadcast to a radio server, live365.com, set all credentials, everyone sees my audio tags but no audio
I tried using VDJ Broadcast, nothing I'm off Air, nothing I do rectifies this, signed out signed in, allow incoming communications on port 8000, nothing..
I'm at a lost, spent more than a few hours on this, googling my problem.. Had folks from radio show look at my configs, checked firewall, VDJ is set for out-incoming communication.
Thanks Suga Ray
Thanks Suga Ray
geposted Wed 12 Oct 22 @ 8:45 am
Have you tried to record to a local file ? Same issue , no sound ?
Any chance you have a record entry in your Audio Setup that doesnt carry any audio ?
Can you post a pic of the AUDIO tab of VDJ settings ?
geposted Wed 12 Oct 22 @ 10:43 am
music files are fine, it's a VDJ issue to port 8000 issue..Thanks
Ray
geposted Wed 12 Oct 22 @ 6:22 pm
Broadcast settings
geposted Wed 12 Oct 22 @ 6:23 pm
geposted Wed 12 Oct 22 @ 6:24 pm
This is what I get..Thanks
Ray
geposted Wed 12 Oct 22 @ 6:25 pm
Does anyone want to help, I can record audio fine... what do ai need to do?
Thanks
Thanks
geposted Thu 13 Oct 22 @ 8:46 am
Post a picture of your vdj audio setup
geposted Thu 13 Oct 22 @ 8:56 am
Hi, it’s posted above? Are asking for output setting, channel mapping? Speakers, sound card?
Question do I need to change input to record?
geposted Fri 14 Oct 22 @ 2:13 am
outputs/inputs/hardware a pic of your audio config
geposted Fri 14 Oct 22 @ 2:27 am
here you go.
geposted Fri 14 Oct 22 @ 4:56 am
if you don't have an actual audio feed going back in [which looks to be the case] then delete the input, you're currently using a source that isn't plugged in for broadcast.
geposted Fri 14 Oct 22 @ 5:10 am
Looks like it was a port 8000 issue, when I ran port checker on port 8000 on Tuesday, port checker said it was open, when I check a few minutes ago, port check said it's closed, refusing connection... I set up port forwarding, am now getting audio via VDJ Broadcast link..
Thanks
Ray
Thanks
Ray
geposted Fri 14 Oct 22 @ 5:43 am
if you don't delete that record input i doubt it will work with live 365 :-)
geposted Fri 14 Oct 22 @ 9:26 am
Copy that … thank you 🙏
geposted Sat 15 Oct 22 @ 7:47 am
Hello I’m having the same problem.. how did you “port forward” to make it work?
geposted Thu 03 Apr 25 @ 5:05 am
