Topic: Virtual Dj 7 Skin 1920X1080
Hello,
I had to re install Virtual DJ on my new computer. I don't find anymore the Virtual Dj 7 Skin 1920X1080 for Virtual DJ 8. Where can I find it?
thank you very much!
geposted Wed 12 Oct 22 @ 6:27 pm
thank you for your answer. It was not that one.
Here was the one I used :
I'm not able to find it anymore
the rhythm wave won't work, you'd have no pads, no custom buttons, no stems.
that skin's for a software that stopped development 8 years ago
It should still be on your old computer?
As Loco says that's from when dinosaurs roamed the earth and isn't really compatible with newer versions of the software.
I need virtual dj 7 skins can some one help me with it
