Topic: XDJ-XZ
Hi guys, is it at all possible to be able to get the search function on the XDJ-XZ in control mode? I want to be able to search for tracks without having to open the MacBook. I’ve tried mapping it but have failed many times.
Also I’ve managed to find a hack to use stems on all 4 channels, I did this using the DDJ RX with the XDJ-XZ, would this work with a smaller 2 ch controller that could be tucked away or is there a better & more convenient way. Thanks in advanced you guys are smashing it, keep up the good work.
geposted Tue 18 Oct 22 @ 8:38 pm
No, there's no possible way to use the "stand alone" search function in "control mode"
The device itself doesn't support it. As also all similar Pioneer equipment (like CDJ2000NXS2)
That’s a shame, thanks for your reply.
