After recording a mix with effects like horns etc. after recording the mix the volume is very low. How do si fix this?
geposted Wed 19 Oct 22 @ 11:24 pm
There can be a few things. Like obviously you need your channel faders all the way up when mixed in, and zeroDB not set too low
You can then sometimes bring the overall volume back up using Audacity or even simply Mp3gain
But some controllers also lowers the recording output by default.
I did a video on this, and what to do about it, a while back
geposted Mon 24 Oct 22 @ 3:05 am
