Who can we get a new syphon plugin from??
This is long over due.........
geposted Sat 22 Oct 22 @ 3:54 pm
Anyone??
geposted Tue 25 Oct 22 @ 1:22 am
Although it seems there has been some work on making Syphon compatible with Metal, the latest public release is still from 2019 before that work started.
You can give scott's beta plugin a try
https://forum.sbdj.co.uk/viewforum.php?f=21
I'm not sure if it uses the unreleased code from Syphon or if it converts from Metal to OpenGL though, so performance may not be optimal.
geposted Tue 25 Oct 22 @ 6:25 am
From our side, we will probably have a mac version of the NDI plugin, I don't know if that would work with the other software you want to use?
geposted Tue 25 Oct 22 @ 6:26 am
Yes please, the NDI will work with Mix Emergency 🤙🏾
geposted Sat 29 Oct 22 @ 1:42 am
Any headway made on this??
geposted Tue 08 Nov 22 @ 12:56 pm
Yes, but will require some updates within VirtualDJ too, so has to wait for next VirtualDJ update
geposted Tue 08 Nov 22 @ 1:19 pm
Sounds awesome and I can not to try it out!!
Thank you 🤙🏾
Thank you 🤙🏾
geposted Fri 11 Nov 22 @ 2:28 am
NDI-Receive is now available through Extensions for Apple Silicon macs and should work with current VDJ.
NDI-Send will be added later (requires a VDJ update)
geposted Sat 12 Nov 22 @ 3:45 pm
Ok I’ll have to wait for the Send to get finished because I want to send VDJ into Mix Emergency.
Can’t wait 🤙🏾
Can’t wait 🤙🏾
geposted Sun 13 Nov 22 @ 1:56 pm
Now available, should work with VirtualDJ EA build 7333
geposted Sun 13 Nov 22 @ 3:30 pm
Anyway to separate this so I can use it on each deck??
geposted Tue 15 Nov 22 @ 4:23 pm
Just start the plugin on each deck i think?
geposted Tue 15 Nov 22 @ 4:44 pm
I’ll try it again but I swear it would only pick up 1 or the other (which ever I started first)
geposted Tue 15 Nov 22 @ 5:09 pm
Ah yes, the name of the source is always "VirtualDJ", so probably can't tell them apart.
geposted Tue 15 Nov 22 @ 5:18 pm
Yup that’s what it’s doing.
Anyway to rename the plug-in? Like SENDER2 for example 🤷🏾♂️
geposted Tue 15 Nov 22 @ 5:23 pm
No, it's not based on the plugin name, but I'll update soon so that when used on deck it adds the deck number to the NDI name to make it recognizable.
geposted Tue 15 Nov 22 @ 5:41 pm
Awesome and 🙏🏾
geposted Tue 15 Nov 22 @ 5:45 pm
Update should now be available
geposted Wed 16 Nov 22 @ 1:00 pm
Still doesn’t show up at 2 different Sends.
Only 1 instance of VDJ shows up in Mix Emergency.
The name is the same for both decks
geposted Wed 16 Nov 22 @ 11:14 pm
