Going to try my best to describe what happened...
In the middle of introductions at a wedding yesterday, everything went silent mid-song out of the blue. When I looked at my screen, both decks were cleared and my sidelist and automix were empty. It was almost as if VDJ "reset" itself.
I was able to quickly reload my intros playlist (I had it saved) and start playing again (without needing to close/reboot VDJ), but I'm at a loss. I have no idea why this happened.
Help me figure out where to begin. This can't happen again.
geposted Sun 23 Oct 22 @ 12:27 pm
I pretty much had the same issue yesterday. My song didn't stop playing, but my lists disappeared. I thought maybe the hard drive was acting up, but now that I see your comment, I believe it's a glitch with VD. Did you get a Ding sound through your speakers like you were getting a notification? I did and it was quite embarrassing. I was in the middle of a Wedding!!!
geposted Sun 23 Oct 22 @ 1:43 pm
I didn't get a ding, but there was like a brief "crackle" sound before it happened.
geposted Sun 23 Oct 22 @ 1:53 pm
Don't have a clue about Playlist Clearing midset, only I can think of is if that track has a Script at some area that will Clear the the playist (just my guess).
I never had that happened, but an example of what happened to is that I was AUTOMIX during a break and then I heard nothing after that song ended and I rushed to the PC and see what Happened.
The music STOP and I thought AUTOMIX froze but it did not. I check the POI in that track and sure enough I told it to STOP before the AUTOMIX POINT.
Anyway as far as that DING sound, first thing we DJ do is to DISABLE ALL WINDOW SOUNDS (that's it).
geposted Sun 23 Oct 22 @ 1:54 pm
Yeah I'm not sure what happened. It's a track I've played a million times before. Automix was off - I was just using that space as a place to hold the tracks in a playlist at the time. I'm at a loss.
geposted Sun 23 Oct 22 @ 3:55 pm
I HAVE Disabled all of my Windows Sounds. They have always been disabled.
geposted Mon 24 Oct 22 @ 5:06 pm
