Topic: virtual dj on macros Ventura
is there any updates for MacBook Pro as virtual dj is not working on macios Ventura ?
geposted Tue 25 Oct 22 @ 10:38 pm
What is not working exactly?
VirtualDJ runs fine on macOS Ventura here
When I try to reinstall it
It says the installation failed
While having the beta installed an update from inside Virtual DJ failed.
When you selected "Update" in the Update-dialog , VDJ was closed but nothing happened afterwards.
When you tries to restart VDJ there was an error message about missing program file.
Downloading the new version from website and installing it manually worked flawlessly.
I curious to see how it works with release version now.
macOS Ventura working fine here (see below);
Systems Specs;
Main System - MacBook Pro (14-inch, 2021), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.0, External WD Passport Ultra 2Tb HD formatted exFat containing Music & Video databases. VirtualDJ 2021 8.5-arm b7183.
Controllers - Denon MC7000, Denon MC6000 Mk2.
Backup System - MacBook Pro 15-inch 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16gb 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Ventura 13.0, 500gb SSD. Can read/write with NTFS for Windows installed. Bootcamped with Windows 10 x64bit. VirtualDJ 2021 8.5 b7183
I cannot get my MCX8000 to connect to Virtual DJ. Audio plays out of the controller but none of the controls work, and the connect screen never pops up. Please help!!
Similar issue with Numark NV II. Is not recognized as device…
MacBook Pro M2 with Ventura…
Ventura work OK here on mine..
I had trouble when installing VDJ 2023 over the previous version on MacOS Ventura. The installation went well, seemingly, but when I opened the app it had not been updated. I had to uninstall the previous version and then install 2023.
Go figure..
My numarknvii can connect to Mac so air Ventura ,only audio plays .other functions not paying .can someone help me
