Partly due to a previous technical issue, I bought myself a new computer. I have downloaded VDJ, and signed into it ok. However I am having an issue when I have plugged in the controller.
VDJ is clearly sending info to the controller (music is playing out from the right jacks, the unit displays are showing the correct BPM etc), however there is no response to any input.
I have the correct licence for the device
VDJ and device firmware are both on latest
Device shows correctly in Device Manager
Any suggestions?
Win10
VDJ ver: 8.5-64 b7183
Numark Mixtrack Platinum FX
Any suggestions?
Win10
geposted Wed 26 Oct 22 @ 8:55 am
Have you followed the install part of the VDJ hardware guide for the unit?
Using the soundcard in it may just be due to regular USB auto-connect + standard WASAPI driver use
geposted Wed 26 Oct 22 @ 1:07 pm
@klausmogensen: I have. Its fairly modern so the instructions are essentially plug and play.
geposted Thu 27 Oct 22 @ 11:22 am
Perhaps some other Application has taken control of the MIDI Input ?
Still same after restarting computer ?
geposted Thu 27 Oct 22 @ 3:09 pm
@djdad: Yes, its never not been the case on this computer. Other than Audacity, no other music/sound/audio software has been installed. And Audacity is normally not running.
geposted Fri 28 Oct 22 @ 12:22 pm
Can anyone else suggest anything? I have a mostly completed home studio here and I can't do anythin with it at the mo... :(
geposted Tue 01 Nov 22 @ 3:49 pm
Have you tried with the software included in the box ?
You cold also test input with MIDIOX http://www.midiox.com/?http://www.midiox.com/moxdown.htm
geposted Tue 01 Nov 22 @ 7:44 pm
