Topic: Virtual DJ Denon MC700 mapping
Is it possible to download a copy of the original mapping for the Denon MC7000?
geposted Wed 26 Oct 22 @ 3:17 pm
You can simply switch back to default in the mapping screen section in VDJ
If you do want in a file, just make a simple change, like add a space to one of the mappings - then it will save to an XML file in the \Documents\VirtualDJ\Mappers directory, where you can go grab it
Hi Klaus
Thanks for your response. I am needing to get the default as it seems the default on mine has been changed. It doesn't behave the way it should. The fx controls on the Denon don't do what they used to do.
I can select fx 1 on the controller and it works correctly. Fx2 and fx3 are selectable but the rotary makes no changes in VDJ.
Long shot I know but do you have an MC7000? Could you maybe post a screenshot of the fx settings so I can make a comparison?
I think thats because you are in 1 fx mode instead of 3 fx mode
In 3 fx mode ypu comtrol 3 fxs on eack deck
In 1 fx mode you have in-dept comtol of just 1 fx per deck
