Settings have been set up and never changed. Always showed midi 8 0ut. Now as per the photo it changed to midi 4out. No driver updates, panel on front is set to 8 out.
Any suggestions as to how this can be remedied please?
geposted Sun 30 Oct 22 @ 5:52 pm
looks correct
compare here https://virtualdj.com/manuals/hardware/americanaudio/vms5/installation.html
there is some mention of the 8 out on this manual for the device prob what you need
https://d295jznhem2tn9.cloudfront.net/ItemRelatedFiles/8856/vms5_0.pdf
there is a switch on the device to change modes its referenced in the manual above
geposted Sun 30 Oct 22 @ 8:53 pm
Yes, settings are correct. Front of the panel on controller is set to 8 out.
But in the Asio setting is shows 4 out. I cannot get that to change to 8 out.
Also backup system works .
Heard something about WASAP. Should the sound be changed to this instead of ASIO?
geposted Mon 31 Oct 22 @ 11:59 am
if the switch on the hardware is not functioning sounds like you need to consult American Audio's help :-)
wapsi is just another type of audio driver it wont help if the switch is broken.
geposted Mon 31 Oct 22 @ 12:15 pm
Don't believe it's the switch as backup works. Just cannot get the midi to show 8 out.
geposted Mon 31 Oct 22 @ 1:22 pm
