Hi all. I'm new here and to DJing. I have a Mixars Primo and I noticed that the sync button works, but when I press shift>sync it does not turn off. I have to move the tempo slider to turn it off. I tried the same action on Serato Pro and when I press shift>sync on Serato it turns off sync and moves the tempo back to the original speed. Am I missing something? Is there a way to map the shift>sync action to do the same as Serato? Thank you.
geposted Mon 31 Oct 22 @ 11:13 pm
here is the VDJ manual for your controller to learn how its been mapped to work with VDJ
https://virtualdj.com/manuals/hardware/mixars/primo.html
here is a small part from that manual
SYNC: Press this button to automatically match the corresponding Deck's tempo with the opposite Deck's (or the Master Deck’s if using a 4 decks Skin) tempo and phase.
Hold down SHIFT and press this button to manually select this deck as the Master Deck.
Hold down SHIFT and hold this button down for 1 sec to resume automatic selection of the Master Deck.
geposted Tue 01 Nov 22 @ 12:52 am
