Forum: Wishes and new features
Topic: Automix - Move track to top
Would be great if you can right click on a track in the automix and have the option to move it to the top / beginning of the auto mix list
geposted Tue 01 Nov 22 @ 8:45 pm
You can, but the option only appears with automix active. Play next.
Thanks, I don't use the automix like that I tend to you that as a pick list, hence it would be good to right-click on the track and "move to top" otherwise I have to select the track and then scroll all the way up to the top.
The reason for it it is easier to find the tracks that I may want to play that evening I DJ for social dancing
Sadly that's the way it works. You could quickly enable automix, click the option then disable it again.
have a keybind browser_move top
