V8.5-64 b7183 bug when turning ON button and FX1
with any effect the volume is muted. To reactivate the volume you must turn off the effect and move the channel fader
geposted Wed 02 Nov 22 @ 1:01 am
Perhaps your Audio Setup is missing the necessary deckfxsend/return lines ?
https://virtualdj.com/manuals/hardware/reloop/elite/setup.html
geposted Wed 02 Nov 22 @ 2:08 am
In the hardware tab I don't see the RELOOP ELITE option, I can't add the deckfxreturn either.
It seems that the software does not fully detect the device.
geposted Sun 06 Nov 22 @ 12:17 pm
Are you on Windows or Mac ? Drivers installed on windows ?
If still no button to apply the default Audio setup, you can still press the LINE INPUT button to create 2 additional lines, then manually edit the line in 1 and line in 2 texts with the deckfxsend/return 1/2 texts as per manual.
geposted Sun 06 Nov 22 @ 1:09 pm
windows 11 10.0.22621
Reloop-Reloop_ELITE_2.9.92.3
geposted Sun 06 Nov 22 @ 1:33 pm
I reinstalled the driver and it worked. Thank you
geposted Sun 06 Nov 22 @ 1:37 pm
When selecting the same effect in fx1 fx2 and fx3, when I want to turn on a single fx, all 3 effects are activated
geposted Mon 07 Nov 22 @ 12:32 pm
you can only have one instance of a fx running on a deck. With downloaded fx you can get around this by renaming different instances of a fx, but inbuilt fx you can't do this.
geposted Mon 07 Nov 22 @ 1:10 pm
