Hi
I'm looking for information. How do I change latency settings for Pioneer equipment. In VDJ - Audio Settings - is still the standard setting 256 samples. I changed the Pioneer settings utility and VDJ latency settings. It's not helping.
geposted Thu 03 Nov 22 @ 10:56 am
if you are using a asio driver you change it in the pioneer asio control panel
otherwise turn on exclusive audio access in virtual dj options and change the latency in the audio panel in virtual dj
geposted Thu 03 Nov 22 @ 12:15 pm
I understand. Will the effect of the changes be visible in the VDJ - audio settings of the sound card? will 5ms 256 samples still be there ?
geposted Thu 03 Nov 22 @ 1:06 pm
It should be
geposted Thu 03 Nov 22 @ 4:41 pm
It should be but there isn't. So you are not sure that the changes are working. When i use asio4all driver for test the changes are visible ;/
geposted Thu 03 Nov 22 @ 5:01 pm
