Hi guys , Am having an issue with my dj-1000 , the cue button just stopped working . tested it in Rekordbox and it works fine . Firmware is uptodate Ver.1.12 .
Many tnx
Many tnx
geposted Sat 05 Nov 22 @ 8:28 am
The CUE button above the PLAY button or the CUE buttons on mixer channels ?
Both (all) or some specific ?
Same if the factory default Mapping is selected ?
Your Audio Setup is as per the manual ? https://virtualdj.com/manuals/hardware/pioneer/ddj1000/installation.html
geposted Sun 06 Nov 22 @ 1:33 pm
Tnx man, I have done all the deletes and reinstalls, update of all software's and firmware's and still no luck the main cue button above the play button is the one that is still not working.
geposted Sat 12 Nov 22 @ 3:48 pm
Can you try and remap the button?
geposted Sat 12 Nov 22 @ 6:29 pm
Excelllent Man , for future reference all I did ws open the mapping window and selected the DDJ1000 cliick save and closed the settings window . Thanks .
Bid Up The Vdj community !!!!!!
geposted Mon 14 Nov 22 @ 1:24 pm
