Topic: Reloop Elite Mapping
LCD BEATS key only shows beats parameter value in display, how can I show the value of any another effect parameter? for example the Room Size parameter of Reverb effect.
geposted Mon 07 Nov 22 @ 12:54 am
U cant. The device firmware is designed and limited to provide certain numbers/texts, so suitable for Beats only.
Currently the software allows to activate 3 effects at the same time. Is it possible to activate only 1 effect at a time, for example, every time I activate an effect the others are deactivated?
