Topic: Virtual DJ Crashes my Windows 11 Machine
I have recently swapped over from Mac over to a brand-new Windows 11 machine and or some reason every so often despite being a brand-new machine when I try to use Virtual DJ it intermittently hangs the entire machine and stops responding. Forcing me to switch off and switch on the machine. I couldn't afford another Mac hence the switch however since swapping over to Windows I have been deeply unhappy. Also, my professional microphone goes completely echo like.
Can anyone suggest any ideas for a fix for this.
geposted Thu 10 Nov 22 @ 4:19 pm
If you're online and it's a VDJ crash then it will automatically be uploaded to the developers.
If it's a Windows freeze and hang possibly not. First thing to check is that your graphics drivers are up to date.
kevinjmann wrote :
...a brand-new Windows 11 machine...
An "brand-new machine" is a bit of a red flag
A new laptop usually needs a bit of preparation before being ready to be used for DJing
Like described in this post:
https://www.virtualdj.com/wiki/PC%20Optimize.html
