hi everybody-
a quick question :
when i am running a custom mapper on my ddj-rr i cannot change the pad order : lets say pad 1 is hotcues & pad 2 is slicer on my controller. I want to have the pad 2 to be stems.
I somehow remember that you can do this only on the default mapper (for some reason i do not remember..)
Is there a way for this to be done on a custom mapper ?
thanks in advance
a quick question :
thanks in advance
geposted Thu 10 Nov 22 @ 10:51 pm
...anybody ?
probably everybody is busy with stems 2.0.
geposted Sun 13 Nov 22 @ 4:25 pm
On your custom mapper your PAD MODE buttons must be mapped as "pad_page 1" "pad_page 2" e.t.c.
Then you can use the GUI to assign pages on each pad mode button
geposted Sun 13 Nov 22 @ 6:01 pm
thanks for the reply
so you mean that for example
<map value="PAD_MODE_SAMPLER" action="pad_page 'sampler'" / should be "pad_page 1"
and
<map value="PAD_MODE_HOTCUE" action="pad_page 'hotcues'" /> should be "pad_page 2"
etc
is that correct ?
and
etc
is that correct ?
geposted Mon 14 Nov 22 @ 7:46 pm
Yes. However, for most controllers I'm aware, HOTCUE would be pad_page 1 and SAMPLER would be pad_page 4
Anyway, just number them from left to right in the order they appear on your controller.
This will ensure proper page assignment.
geposted Tue 15 Nov 22 @ 1:40 am
understood !
thank you !
i will try it.
thank you !
i will try it.
geposted Tue 15 Nov 22 @ 4:54 am
one more question :
do i also have to change the LED_PAD_MODE_HOTCUE etc for the led's to work correctly ?
geposted Mon 28 Nov 22 @ 12:20 pm
Yes.
Just check the original mapping and change accordingly.
Typical mappings are pad_page 1 or pad_page 4 ? blink : pad_page 1 depending on your controller.
geposted Mon 28 Nov 22 @ 1:35 pm
I am on a ddj rr pioneer controller.
So just to get it right :
These are the lines that I would have to change :
<map value="PAD_MODE_PADFX1" action="pad_page 'Loop Roll'" />
<map value="PAD_MODE_SLICER" action="pad_page 'slicer'" />
<map value="PAD_MODE_SAMPLER" action="pad_page 'sampler'" />
In to :
<map value="pad_page 1" action="pad_page 'hotcues'" />
<map value="pad_page 2" action="pad_page 'Loop Roll'" />
<map value="pad_page 3" action="pad_page 'slicer'" />
<map value="pad_page 4" action="pad_page 'sampler'" />
And these values :
<map value="LED_PAD_MODE_HOTCUE" action="pad_page 'hotcues' ? color 'red'" />
<map value="LED_PAD_MODE_PADFX1" action="pad_page 'Loop Roll' ? color 'cyan'" />
<map value="LED_PAD_MODE_SLICER" action="pad_page 'slicer' ? color 'magenta'" />
<map value="LED_PAD_MODE_SAMPLER" action="pad_page 'sampler' ? color 'violet'" />
In to what ? :
To something Like this ?
<map value="LED_PAD_MODE_ pad_page 1" action="pad_page 'hotcues' ? color 'red'" />
<map value="LED_PAD_MODE_ pad_page 2" action="pad_page 'Loop Roll' ? color 'cyan'" />
<map value="LED_PAD_MODE_ pad_page 3" action="pad_page 'slicer' ? color 'magenta'" />
<map value="LED_PAD_MODE_ pad_page 4" action="pad_page 'sampler' ? color 'violet'" />
Is that correct ?
Or am I doing something wrong ?
Thanks for the help
In to :
And these values :
In to what ? :
Is that correct ?
Thanks for the help
geposted Mon 28 Nov 22 @ 11:39 pm
You should change
To :
<map value="PAD_MODE_HOTCUE" action="pad_page 1" />
<map value="PAD_MODE_PADFX1" action="pad_page 2" />
<map value="PAD_MODE_SLICER" action="pad_page 3" />
<map value="PAD_MODE_SAMPLER" action="pad_page 4" />
And
To:
<map value="LED_PAD_MODE_HOTCUE" action="pad_page 1 ? color 'red'" />
<map value="LED_PAD_MODE_PADFX1" action="pad_page 2 ? color 'cyan'" />
<map value="LED_PAD_MODE_SLICER" action="pad_page 3 ? color 'magenta'" />
<map value="LED_PAD_MODE_SAMPLER" action="pad_page 4 ? color 'violet'" />
To :
And
To:
geposted Tue 29 Nov 22 @ 1:01 am
Thank you very much George !
I am amazed every time by the support (global & local) in this forum for its members !
support : one of the best selling points ( after the amazing software off course among everything else ! ) in Virtual Dj software.
geposted Tue 29 Nov 22 @ 4:55 am
Comment fait-on pour déverrouiller un contrôleur avec la licence pro ?
geposted Tue 29 Nov 22 @ 5:22 pm
