Hi,
On Macs with notch, the phrase counter widget in the top center of the pro skin is hidden by the notch.
Could we have an option to move it to the left or right? Just let it float up against the other widgets on either left or right.
Thanks!
Thanks!
geposted Sun 13 Nov 22 @ 7:21 am
Try changing maximized option value from 2 to 1:
geposted Sun 13 Nov 22 @ 11:06 pm
Yeah, you can also switch between the different `maxImized` modes by using the green button.
But I really want to use all the screen estate for VDJ. I don’t want to see the top bar or the dock.
So, VDJ devs, would it be possible to mark the notch-area as off limits for widgets?
geposted Wed 16 Nov 22 @ 6:02 pm
It can be done. There is an option called has_notch which could be incorporated into skins to move those elements when maximised.
geposted Wed 16 Nov 22 @ 7:37 pm
Thanks Dan, good news.
Feature request: Incorporate the ‘has_notch’ feature in the standard skins. 😛
geposted Wed 07 Dec 22 @ 5:39 pm
