I have a M1 MacBook yet I'm getting this message
What is going on here???
geposted Sun 13 Nov 22 @ 4:15 pm
Interesting. What happens if you actually let it try seperating with the new engine?
geposted Sun 13 Nov 22 @ 4:19 pm
Are you using rosettta perhaps?
geposted Sun 13 Nov 22 @ 4:31 pm
It takes about 5 minutes to process
geposted Sun 13 Nov 22 @ 4:32 pm
Yes I am.
Thought I had to have that selected for the screens on my Denon 5000's to work??
geposted Sun 13 Nov 22 @ 4:33 pm
No, that's not needed
geposted Sun 13 Nov 22 @ 4:34 pm
Ok I just turned it off and now I have to update my OS because I’m still on 11.something.
I’ll update and test in a few hours.
Oh and NDI is working great with Mix Emergency!!
Thank you so much for that 🙏🏾
geposted Sun 13 Nov 22 @ 4:38 pm
Holy shit 🤯
Stems are sooooooo much better!!
Y’all have really out done yourself this time!!
1 question tho, I’m not seeing a bleed knob or buttons anymore?? Does this have to be mapped or am I looking at the wrong spot??
geposted Sun 13 Nov 22 @ 8:14 pm
Stems 2.0 don't have/require/use "bleed" anymore.
Bleed is still there though for Stems 1.0 engine. So, if you switch to "Reduced Quality" you'll get bleeding back.
geposted Sun 13 Nov 22 @ 8:28 pm
Naw I’m good with how it’s sounding now 🤙🏾
I would like to see a simplified pad mode tho.
Like right now if I want just the drums I have to press 3 buttons to get just the kick/snare.
So maybe a pad mode with a Vocal button, Instrumental button, Bass button and then a Drums button (only the kick/snare) then do whatever you want with the left over buttons lol!!
Other then that I am impressed!!
geposted Sun 13 Nov 22 @ 8:52 pm
You can easily do it yourself.
Click on the "stems 2.0" dropdown, and choose Edit...
Then select the pad you want to modify (for example Pad 6), and replace stem_pad 'hihat', by stem_pad 'rhythm' in the field on the right, and replace in the name field to Drums.
Then just close the edit window, and enjoy your drums pad, that was that easy.
geposted Mon 14 Nov 22 @ 1:57 am
Just want to say thanks to the VDJ team for this update. The stems sound is definitely improved
geposted Mon 14 Nov 22 @ 2:05 am
