BUILD 7349 (2022-11-18)
Is there an error? The "Stems" folders react differently than in the previous build.
geposted Fri 18 Nov 22 @ 4:33 pm
Can you explain further ?
geposted Fri 18 Nov 22 @ 6:21 pm
Is it a mistake or am I doing something wrong?
See video:
https://photos.app.goo.gl/JfNgwLFozyBX3dvU6
See video:
geposted Sat 19 Nov 22 @ 4:23 pm
All My STEMS Are all remove or lost..dont see Them over 10,000 GONE something not right with the NEW STEMS and not in the backup also.& what’s this can’t remove this box unless close VDJ
geposted Sun 20 Nov 22 @ 6:12 am
Your stems won’t have ‘gone’. However the icon will only show for 2.0 processed stems.
geposted Sun 20 Nov 22 @ 12:04 pm
This is the second time this has happened.
Stems engine error: 422/1
Stems engine error: 428/6
The log file is full of this entry
geposted Sun 20 Nov 22 @ 1:25 pm
is there differs with v2 .0 & 1 .0 Icon
geposted Sun 20 Nov 22 @ 4:42 pm
Does nobody have an idea what the error means?
Does one of the developers want my LOG file? please report!
geposted Sun 20 Nov 22 @ 7:47 pm
please try to update your graphic card drivers to the latest version.
which graphic card do you have, and with how much dedicated video memory?
geposted Mon 21 Nov 22 @ 5:27 pm
GTX 1050 Tl 4GB Grafik und 16 GB System RAM
CPU AMD 6 Core.
CPU AMD 6 Core.
geposted Mon 21 Nov 22 @ 5:58 pm
Check nvidia.com for latest driver. You card should offer Driver Version: 526.98
geposted Mon 21 Nov 22 @ 7:54 pm
Ja, habe ich gemacht. Und nun scheint es zu laufen.
Ich werde berichten.
Aber ich brauche neue hardware :)
geposted Mon 21 Nov 22 @ 8:01 pm
