Topic: XDJ-RX2 waveforms
J@vierCPRO InfinityMember since 2014
Hi , anyone can help me if possible ?
In my xdj-rx2 virtual work ok, except the waveforms not show in sinchrony when mixing, sound is ok, but the waveforms not are aligned beats . you know how to fix it? Thanks in advance.
Xdj-rx2 is updated to last version , and vdj also.
geposted Sun 20 Nov 22 @ 10:29 am
Pioneer gear traditionally does not allow the "stretch" of the waveforms in order to align the beats (as VirtualDJ GUI does)
On Pioneer gear what happens is that instead of stretching the waveform and keep it moving in a constant speed, the waveform just slows down / speeds up as you change tempo/speed.
This means that on Pioneer gear you should only focus on the "center line" of the waveform display, as that's the only place where beats align even on perfectly synced tracks (as soon as they have different BPM that requires different pitch/tempo in order to sync)
I hope this info helps you understand how it works and that it can't "be fixed"
geposted Sun 20 Nov 22 @ 4:16 pm
Thank you perfectly explained.
geposted Sun 20 Nov 22 @ 6:14 pm
