when open VDj NOW the FAN come on les then 40s after open it KEEP running,& why the stems keep separating/analyzing with no music showing?
geposted Sun 20 Nov 22 @ 4:23 pm
It keeps the history of the pending precomputing stems in a xml file and load it when you launch virtualdj, to resume the process at the last status. So it means you had something pending in the stems folder.
geposted Sun 20 Nov 22 @ 5:53 pm
And where is this XML file? And the name?
geposted Sun 20 Nov 22 @ 6:05 pm
tasks.xml in the VirtualDJ home folder.
If you close VDJ and delete the file it won't resume scanning when you reload.
geposted Sun 20 Nov 22 @ 6:09 pm
ok
geposted Mon 21 Nov 22 @ 1:25 am
You can also just go to the Stems folder and delete the queued tasks there. No need to modify xml files.
geposted Mon 21 Nov 22 @ 4:38 am
