Virtual dj issue with pioneer ddj-sx2
when loading up the controller doesn't seem to sync with the mapping since there was an update on virtual dj software
just loads up channels 3 and 1
geposted Mon 21 Nov 22 @ 11:21 am
Default Mapping was updated to support Deck Clone. Dont the LOAD buttons work as described here https://virtualdj.com/manuals/hardware/pioneer/ddjsx2/layout/browser.html (Nr.46) when the factory default Mapping is used ?
For those that dont, perhaps the INPUT selectors at the front (Nr.62 https://virtualdj.com/manuals/hardware/pioneer/ddjsx2/layout/front.html ) are not in PC position ?
geposted Mon 21 Nov 22 @ 1:46 pm
After updating to build 7356 on my Pioneer DDJSX2 my left deck performance pad doesn't respond to pressing as before. Hotcues aren't stuttering or precise it seems to drift 3-4 beats . I cannot figure out scripting to set things back to normal.
geposted Tue 06 Dec 22 @ 10:47 pm
Make sure you have quantize and smart_cue turned off
geposted Wed 07 Dec 22 @ 3:49 am
