I just had a couple of graphics (driver?) crashes with VDJ2021 b7358, maybe 1/2 into a pure audio set that was being recorded
The audio continued, while the graphics froze, the scree turned black, and then it came back- The Stems engined restarted (it said Starting Stems Engine above the search field), and it had the automatically set Stems separation to Don't Use GPU
I'm not sure if you receive those kind of crashes :)
After all of this something similar happened a couple more times and the graphics continuously became kind of jerky
My GPU is a GTX-1650
Should I maybe try the new Early Access release?
geposted Sun 04 Dec 22 @ 2:03 pm
Perhaps check the system event viewer to see if a hardware / driver error was logged
geposted Sun 04 Dec 22 @ 2:18 pm
I found this:
Not sure if it's related...
- System
- Provider
[ Name] Windows Error Reporting
- EventID 1001
[ Qualifiers] 0
Version 0
Level 4
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2022-12-04T12:55:35.1983047Z
EventRecordID 6708
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel Application
Computer DESKTOP-854AB74
Security
- EventData
1929624135118660908
5
RADAR_PRE_LEAK_64
Ikke tilgængelig
0
virtualdj.exe
8.5.7356.0
10.0.19042.2.0.0
\\?\C:\Users\Klaus\AppData\Local\Temp\RDREB33.tmp\empty.txt \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREB63.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREBA3.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREC0E.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERECAB.tmp.txt
0
096cabfb-cc54-48cf-8513-2281185c5594
268435456
302173c71d2a6ecb7ac766ed63c4a52c
0
- System
- Provider
- EventID 1001
[ Qualifiers] 0
Version 0
Level 4
Task 0
Opcode 0
- TimeCreated
EventRecordID 6708
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel Application
Security
- EventData
1929624135118660908
5
RADAR_PRE_LEAK_64
Ikke tilgængelig
0
virtualdj.exe
8.5.7356.0
10.0.19042.2.0.0
0
268435456
0
geposted Sun 04 Dec 22 @ 2:37 pm
