Did something change with Virtual DJ 2023 that messed up all my mapping with Effects and Prime 4?
on my FX
The FX Select wheel now does the Param 1, Param 1 does Param 2, Fx Wet/Dry now does Video Effects.
How can I set that back up to how it was?
If I change the Mapping on VDJ the displays on my Prime 4 do not match what the displays are on my prime 4
Thank you for any help
on my FX
geposted Mon 05 Dec 22 @ 3:11 pm
Nothing is changed in regards to Prime 4 default Mapping. the FX operation is still as described here.. https://virtualdj.com/manuals/hardware/denon/prime4/layout/effects.html
Have you modified the default Mapping (created a Custom one) ? If so, is it still available in the Mappings drop list in VDJ Settings MAPPING tab ?
geposted Mon 05 Dec 22 @ 3:19 pm
Yeah.. Mine no longer works like that. It was working fine and it changed when the 2023 version kicked in.
now the mapping is off.
Btw. The Prime 4 did not get an update after the virtual dj update.
Nothing has changed on my setup for months. the only change was the update to VDJ 2023.
Thank you for any help you can provide
geposted Tue 06 Dec 22 @ 12:23 am
I just plugged Prime 4 in VDJ 2023 and everything works as described in the manual.
Please make sure you are looking at the correct section Single/Multi FX, depending on the selected mode from the GUI.
From your description, it seems that you are in the Multi FX mode, while most likely you expect to get the functionality of the Single FX.
geposted Tue 06 Dec 22 @ 12:48 pm
