Hi guys... all my video effects seem to work fine except for the "text" effect. As soon as i activate it, my video output goes completely black.
This only happens if the video output is set to full screen. Does not happen in windowed mode.
Wonder if anyone can shed some light on a fix for this please.
Thanks! :)
Thanks! :)
geposted Fri 09 Dec 22 @ 1:12 pm
Does it happen with any text you enter?
geposted Fri 09 Dec 22 @ 1:35 pm
NO!!! How weird!
geposted Fri 09 Dec 22 @ 1:40 pm
So i've just had a little play around, and there seems to be a character limit!
Yet there isn't a limit if it's in windowed mode!
geposted Fri 09 Dec 22 @ 1:46 pm
Depending on the video card, there is a limit in the size (in pixels) of the text, which explains why you would reach the limit quicker when full screen.
You can split the text on multiple lines to overcome this limitation however.
geposted Fri 09 Dec 22 @ 1:49 pm
Handy to know! Thanks bud!
