Topic: Remix field in Deezer
Hi
When searching music in the browser, the remix of the track is not appearing in the 'Remix' column for tracks found on Deezer. If I use the 'Title (remix)' column rather than separate 'Title' & 'Remix' columns, the title + remix for files found on Deezer will appear in that column but the separate 'Remix' column is always blank for Deezer files.
Is there something I need to do to correct this?
Thanks
geposted Sat 10 Dec 22 @ 2:29 pm
Make sure getRemixWhenParsingFilenames is enabled
That worked thanks, stupidly I was assuming the option was only for local files when adding to the database so had turned it off.
Thanks again
