The Back Up is still saving in documents not Application support.VDj makes a folder and in the folder it a backup folder only of VDj info.
geposted Sat 10 Dec 22 @ 10:01 pm
Correct. The reason for this is so that you can easily find your backups, and so that in case you have cloud backups of your documents activated, the backup is stored there as well.
If you prefer another location, you can change the databaseBackupLocation option
geposted Sun 11 Dec 22 @ 6:06 am
cool I have been after seeing it not there, just putting in note for others not sure. Thank you Dj.
geposted Sat 17 Dec 22 @ 4:00 pm
